Vmi / wildchild racks
sledneck_03
What are you guys carrying on your racks? I ran one on my 155 iq but the can wore into the tunnel top a bit.
Im going to order the wildchild 163 doo rack with the rods under the can and order 4 more rods for under the back cargo area. This should strengthen the tunnel a bit as well as i can strap almost anything into that area and it will sit off the tunnel. Hope he can switch out the rods and mounting hardware for polaris ones.
VMI RACK
I have had VMI on my 12' and 13' PRO's. I carry 2-2gal square gas jugs and a PVC North Face duffle bag. Just go to Lowe's or Home Depot and get a few 2" X 1/4" thick round or square rubber grip pads that go under furniture or desks to keep from scratching hardwood floors or tile, with adhesive backs, no more rubbing on tunnel, works great. The Doo rack sits a lot higher to allow for the rod in the bottom holes. the poo version doesn't have holes for rods in the bottom, as you've probably seen, I didn't like the height of the doo.
Doo rack FYI
Forgot to say if you order a doo rack, be sure they send you Polaris rods, the door rack rods obviously are too wide and you can't cut them down to fit. I had to return mine twice and they still couldn't get it right, I had to go buy Polaris rods from a dealer....good luck
