Benders Instructions call for 162.5 Mains, and 52.5 pilots @ sea level. I still have my instructions and they are in good shape. I will post them up later today for ya, (my girl has a scanner at work).
Benders instructions want you to cut big holes in the air box, and remove the internals. MPI who was a Bender rep at the time did not recomend any ari box mods. They do however stress the use of the "Bender opticool" head gasket. See Below:
MPI Jetting/Clutching @ 8000ft 10-30Deg F
MJ#1 - 143
MJ#2 - 143
MJ#3 - 145
Needles - Set @ 2 position
Pilots - 60's
Weights - 8DN-10
No inner rivits
2.4grams in outer hole
14.5mm rollers
yel/wht/yel or grn/wht/grn primary spring
helix 48-42 or 48-40 roller
green secondary spring
70 deg twist
20/40 gearing
Sean
