Here is the link to the video of my 2009 RMK 700 top end bog... Thanks for helping out guys ! It's really appreciated !
https://www.youtube.com/watch?v=C6U2KPGbmpA
test your fuel psi if the psi drops when you pin it the pump is probably bad
TPS-either bad or not adjusted properly. I've seen TPS in other applications work when engine was cold but fluctuate wildly in resistance when warmed up.
Fuel Filter
Exhaust Valve?
Also do a compression test before you get too deep into this. Depending on your gauge and elevation your testing at, you could see anything between 100-150psi. The main thing is they are both with in 10% of each other and over 100 psi.
Remove both spark plugs, key turned off, hold throttle wide open and do 5 strong pulls on each cylinder. Eric
