Vibration and idle speed 800r
The 800r is known for vibrating at idle. I like mine to idle between 1700 and 1900 rpm. If you want it lower just back off the idle adjuster screw on top of the carb rack. Should be a round silver knob. It will however idle rougher at less than 1700 rpm's. Both of mine do.
The lower the rougher it seems....I've never seen one that didn't shake like a bastage at any idle tho. Too low an idle and the handwarmers don't like to heat up and the DES or whatever doesn't boot up and get the tach going.
