VES cleaning
i have seen somewhere on here how to clean the VES,but where i can't find it..I have never cleaned them before so i just wanna make sure i am doing it right and using the proper tools,cleaning solution...If anyone has a video clip,pics or a step by step on how to do this i would really appreciate it.Thanks
Remove the side panels. Remove the hood. Remove the pipe. Remove the upper plastic thing from the steering thing (13mm). Remove the outer plastic thing from the right valve (seen from the front of the sled 10mm). Remove the valve itself right). Remove the left one without removing the plastic thing . When you put it back. Be careful with the bolts. Should take about one hour.
Rudy, you dont need to use any cleaning solution. Just use a brush wheel on a bench grinder. Super fast and super easy.
