Do you move the ves breather away from the clutch side?
On the old edge sleds the carbs would feed more fuel from the increased air flow when the exhaust valves opened. On the cfi motors the ecm will not increase fuel flow when the valves are opening early because the sol. valve was disconnected. By disconnecting the sol. valve it may cause a lean condition in low mid range.
