Ok I have done a search and found a few things but not really everything I was looking for.
I just got my first enclosed and am looking at putting heat in it. I'm debating on weither I should put in an rv furnace or a ventless wall mount heater. From what I've found the furnace is a "better" heat, but the ventless with a fan will still dry out gear. I want to be able to have heat for at least a couple days without the truck being hooked up. I plan on getting a little generator, but don't want to have to run it 100% of the time. From what i understand, if I go with forced air I will need a battery bank, inverter, propane, and furnace. And if I do a ventless I just need the propane and heater. Will probably do a little battery either way to be able to turn on 12v lights without the truck.
So with this set up what am I actually looking at for cost differance between the two? And other than dryness of heat are there any downsides to the ventless?
Thanks in advance
Thanks in advance
