Not much meat there that isn't critical to strength, also holds the ramps and the bubber damper is riveted. All the power goes through this before it gets to the sheaves.....
OK, I'm probably going to be pointed and laughed at, but what if you were to add a RC airplane prop to the outside of the clutch, as rpm increases, so does the airflow over the clutch. Wouldn't affect balance, might lop some fingers off, though!
does every one have problems with skidoo clutches running hot?
