Has anybody used the holz venting kits? If so did they work good?
Great, I just finished putting mine in yesterday. So now I get to look forward to clutch slippage?? Not cool.
So I installed the shock tower vent on my dragon to allow cool air to my turbo. I decided to not put the one on the clutch side because I was sceptical on them not leaking snow. Well let's just say they have a slight leak. The right side of my sled was completely packed with snow. Finally engine heat melted the snow and created an ice layer that blocked more snow from coming in. I am talking a good 2 cubic feet of snow on the right side of my sled. Wish I had a camera to send to holz and show them. You will defiantly need screen material. If you go riding before then just tape of the vent or else you WILL have snow coming in.
I ordered HRP vents a mounth ago and just got them today. Glad to see they sent some screen with the front panel kit just wish they would of glued it on. Hopefully this will help.
I am reading this 2 hrs late. I just cut my side panel or I would send them back. I ordered the side panel and front panel kit. They only sent screen in one so it isnt enough to do everything. WTF I think the screen will plug anyway because the snow can't get out of the holes in the vent with screen behind them. Ovviously they have not be tested on this sled in deep pow anyway. I woud'nt buy HOLZ vents. Sounds like false advertizing to me.I would send them back if I were you.
Bill,
Remove the side vent and glue some screen door material to the inside if the vent and you'll be ok. If you contact Holz they will send you the required fabric and rivets. Its only the lower clutch vent. You can also just remove your side panel and take it to Carls and they will fix it.
What's the best glue to attach the pre-filter material?
Some use a glue gun and swear by it, I like to use Gasket Sealant, by Mr. Gasket, it is also known as Red Tack or High Tack, I is usualy used to hold a gasket on a part while it is being set in place.
I spray it on the part, let it set up, then apply the SLP material.
I use the prefilter on ALL of my vents, snow comes in from all sides and turns to steam, and affects the whole engine compartment. Filtering just the clutch vent, will help with only the snow that hits that vent, right?
Bill,
