T
Turbo11T
Working on the T-vec custom build and I have a couple questions. Want to get rid of the little metal valve that would be between the tank and the airbox on a stock vector. Can i remove it? What is it's purpose? And just add a overflow can with a return to the crankcase and a breather?
Also what coolant lines should I use for my cooling to the turbo?
Thanks
Here is a pic of the sled. You can see that little valve sticking up in the air in the top right of the pic.
Thanks
