Valve Shim Kits
kinneyt
I am going to help a friend check his valve clearance.
What shim kits have you used and would you use them again. The bike is a 2014 KTM four stroke. My understanding is the all KTM 4strokes 2012+ use the same shims, correct?
If you are going to be doing a lot of valves, the Hot Cams shim kits work great. If you are just doing one bike here and there, I would measure them and see what you need first. Then just go to the KTM dealer and buy the shims that you need. They are usually around $6 to $10 each.
