Yes, I'm doing one tonight. Heat em up with a blow torch. Yours is a switch back or rush style and not a pro rmk one just to be clear.Has anyone successfully swapped the cast steering bracket on the frame? Its bolted in the front and riveted / epoxied in the rear. Will the epoxy give up with some heat. I know they dont sell just that part but it seems like it would be faster and cheaper if i could steal it off a parts machine.
Do you mean to say that you put SwitchBack Assault/Rush steering post castings on an RMK?...I swap rmks to this style as it's much closer to what the 2021s are. Been on it since 2012 and had the rmk since 2011. I could run anything in the world and there is a reason I do the swap. Ebay, specifically Idaho power sports iirc is my preferred, used, chassis parts supplier!
Sent from my SM-N981U using Tapatalk
