Anyone have experience upgrading their 2016-2017 KTM 450sx-f to the the Trailtech 80w upgraded stator from the OEM 25w stator?
I’m curious if the increase in wattage from the new stator is enough to blow out the stock regulator/rectifier, and it’s necessary to upgrade the regulator/rectifier as well.
Is the system three phase or single phase so I can troubleshoot diode connectivity/continuity issues in my current regulator/stator system.
Also wondering if the two yellow wires from the stator that connect to the two yellow wires on the regulator/rectifier matter which one they get hooked up to, or since both are yellow/yellow that you can hook it up to either or, and not worry about positive/negative.
If you’re wondering why I’m even going this route when I could just use the raze heated handlebars...you’re probably right..
Thank you in advance, this forum has been so much help in getting my snowbikes setup.
