So.
What would be the best thing on my new Nytro to upgrade first?
Depends on how much your wanting to spend. But the first mod should be a new track. CE or Powerclaw. single best mod you can do besides boost.
So.
Really?Depends on how much your wanting to spend. But the first mod should be a new track. CE or Powerclaw. single best mod you can do besides boost.
Maybe that was the core issue for me this year.This is a fact! A new track will make a huge difference in the fluffy stuff!
a new track is a must for these units ! almost any track is an upgrade from the mavrick that comes stock. The 162 x16x2.5 is the best but a camo or powder claw off a cat is a cheep upgrade as well . When moving up to a 16 inch wide track you need to change drop brackets as well. i think there around 150 $ and shed 8 pounds . also some bolt grinding inside the tunnel is needed to fit the 16 inch track . also id look at a performance package from some one (clutching power commander pipe and air box ) . that way every thing works together
So VERY LITTLE FLUFFY STUFF!!
So just what exactly is required to upgrade to a 16" wide track?
"Some Bolt Head Grinding" ??
"New Lightweight Drop Brackets" ??
The brackets might be a game ender for me, as the new Skinz Air Frame Boards are pretty dependent on the old drop brackets as a mounting point for the rear end of the boards. I suppose it would depend a whole lot on how the new brackets interface.
in my nytro I have run the 16 wide since day one. You have a 1/8 inch to 3/16 th per side. It works fine but you have to make sure you smooth everything down or flip rivots around that will be in the way. And yes the off set stock drop brackets wont work, you need something that lays flat.
