update for dragon already costing me after 50 miles
rmkboxer
I called the dealer because I had the update done and found the plastic cover over the electronics rubbed through the harness. I have a bog now that I never had before. so heres the new issue I discovered. on my last ride it was boggy and cruising about 30-40mph. and it backfires and gernades my can. I think its a little rich. ran great all last season and have only put 50 miles on it this season. the update was done before the start of the season.
Not sure about the 2009, but if it is the same as the 08, that is not a stock can.
SO - unless it is SLP, put the stock can back on before taking it in for any service or repair! Or Polaris may not cover any repairs.
Which Updates?
RMKboxer, which update did you have done? The piston, head, and new ecu map reflash? If this is the update you have had done there is another new map flash for the ecu to help with the midrange bog, burp, pop, or back fire and hard hot flooded starts.
The old map update program is too lean in the midrange and can burn down the motor if you just hold it steady at mid throttle. The new map is polaris's new fix and it helps according to the new posts on the 4ms. Another choice or option would be to install a power commander five from jim at dynotech.
This should fix your concern unless you have something else wrong? Like sledhed said if you do not have the orignal can or slp can on the sled the dealer may inform Polaris and you may have your warranty coverage voided. Also becuase the engine is so lean in the midrange the burned hole in your can will happen when the can casing is thin and the engine too lean for too long.
its getting the new reflash, I want my original one back, we'll see how it goes. I'm going to buy a slp can. I had no bogs or any issues before the new map. If you ride it like a 2 stroke the old map was great
