Union Bay Triple 1080
Motor was built by Union Bay. Porting by Doug Ruth
They used Price cylinders and an Ultra bottom. Super reliable, easy to clutch. I have run pump gas through it as low as 1500'. I also have another set of race gas domes and spare ignition parts. Motor comes with Crank shop pipes and polished cylinders. Uses stock polaris 82mm pro-x pistons.
Motor will come with mikuni 44mm carbs (2 years old) as well as a fuel pump and primary clutch. Basically everything to make it run. The motor is sound and has been the best ( bar none ) motor I have ever ran.
Yes it is the motor in the sled
I would like to get close to 4K, complete with everything to make it run. Engine plate can be included if it was being put in a Gen2
If I were to buy another motor I would maybe take a step up, not down.
Why run a twin that breaks clutches and needs race gas to make over 200hp?
This motor runs pump and makes over 200 hp and has never broken a clutch or blown a belt.
