N
NINJIN
Ultimate Maine Backcountry Build
Hey all.
Going to start building a new sled as soon as I get out of school in 2 weeks. Done my senior year in Mechanical Engineering Technology. Some have you may have seen my build last fall of the xlt with the tube tunnel. Well that just opened the flood gates for me. After getting to ride it for a week I was hooked on the light weight and super responsiveness that the chromoly has to offer. I am going to build an entire chassis this year. I am going to base the front suspension on the IQ chassis a arms. Going to go either 146 or 155 with this one. Will somewhat base it off of the rest of the IQ chassis also. Going to go with a watercraft triple for a motor. Hopefully 1365, already have the cases.
Also the biggest deal is the rear suspension I am designing. Not going to say anything about it as i will need to try it before I can say anything about it but its def not like anything out there now.
Here is my build plan,
let me know what I should change
Controls
Fastrax Throttle block
Fastrax Wilwood master
Fly aero taper carbon rap mini bend
Fly handle bar hooks
Fabcraft Poly bar and mount
Fly racing riser
Fastrax 4 button billet control block
Powermadd Hand guards
Front Suspension
Walker Evens needle ski shocks
one off chromoly front suspension
Rear suspension
Ice Age Rails
Fox float Front shock
WPS Rear wheels 8" black plastic wheels
WPS Top wheels 4-5/8 inch black plastic
WPS Limiter straps
Ice Age 2 wheel rear axle
Ice age anti stab kit
Rear shock ???
Drive Train
Wahl Anti ratchet Drivers
Wahl Jack shaft and drive shafts
Ebay Polaris Chaincase/ gears/ brake rotor/ caliper 300
Body
MTN fit Hood
MTN fit Vents 12 piece kit
EABY IQR Body work
EBAY IQR Console
MTN fit Side panel vents
EBAY IQ dragon Seat
Ski/Track
Tracks USA 9104 Challenger extreme 155x2.5x15
SLP Powder Pro skis black comp. mount all black
Chassis
Chassis Shop Tubing
Chassis Shop Rod ends
Chassis Shop Tube inserts
Chassis Shop Tank cap
WPS Cooler material
Bangor Steel Aluminum for the tank
McMasterCarr All stainless hardware
Ebay IQ Rack steering
Bangor steel Aluminum for tunnel
McMasterCarr Bushings, cross shafts etc
Engine
Watercraft base all goodies from 1200psi
EV cylinders hopefully 1365
ultra ignition
bored rack slides
www.pcsperformance.com Pipes and porting
Please give suggestions its kinda bugget minded even those obviously not going to be cheap, its just not a 25,000 turbo yami or anything
Hey all.
Controls
Fly racing riser
Front Suspension
Rear suspension
Ice Age Rails
WPS Limiter straps
Rear shock ???
Drive Train
Body
MTN fit Hood
EABY IQR Body work
EBAY IQR Console
EBAY IQ dragon Seat
Ski/Track
Chassis
Chassis Shop Tubing
WPS Cooler material
Engine
ultra ignition
bored rack slides
