Typical broken oil cable
Sask900
New member
Found my oil cable was broken when doing my top end, what do you suggest
For replacing it? Does anyone have cables either aftermarket or OEM??
Brennan
Look at the stickies at the top of the page first, after that of you do a search for "oiler cable", you'll prolly get 100+ results.
In the FBF cable thread that is stickied at the top of forum there is a contact info for Motion Pro they just started making a cable for the 700/900 not too long ago. It is in the last few pages.
Im a tad confused as the stock system has the throttle cable going to the throttle bodies then the oil cable is attached to that for operation, the motion pro shows the oiler cable and throttle cable as one. Can someone help me clarify?
You have to replace the entire throttle cable, this eliminates the breaking of the brass elbow and allows you to remove your throttle bodies without removing any cables.
The motion pro eliminates the cable from the throttle body to the oil. It has 2 cables one goes to the throttle and other goes to the oil. That way you can now take the throttle body off without disconnecting the thecable from throttle to oil which is a pain. Now no cables qto disconnect, just remove throttle body and set aside plus no more brass elbow from throttle to oil to keep on breaking.
yah what he said ^^^^^. I just bought the motion pro and installed it a few months ago. Nicely built cable and it was fast shipping. Good luck
ordered a cable yesterday from pro motion, looking forward to not having to deal with this issue anymore, had 2 oilers break last season and wish I would have read more on here before taking it to the dealer and getting it replaced by the same stock ****, lol but what can you do!
