Sounds of your bike while riding will tell you almost as much as reading your plug so try to learn what lean and rich sound like. When you chop your throttle and hear a little mis, pop or inconsistent sound you are usually lean, if it sounds like its not a nice crisp sound and you see blue smoke when accelerating its rich. Hopefully some on can explain that better. Lean will burn down the motor, rich just won't run that good, so caution on the side of rich when changing rods/jets. The smart carbs are a little tricky to tune as the clicker doesnt have any effect on full throttle, if you're running a metering rod that is too rich you could lean out the motor to the point of being able to burn down the motor running half throttle and almost flooding it out running full throttle. And if youre running a rod thats way too lean you could richen it up enough to hardly run at idle through half throttle and burn it up when you twist it wide open.
