This new clutch cover is a direct replacement for the Polaris 6-1/4" diameter drive clutch. It dissipates heat at a much higher rate than the stock cover due to less mass and the large openings. It is 100 grams lighter that the stock cover also. We have installed a Oiled Bronze bushing so you will never have to replace it. We also have drilled and taped 1/4-20 holes around the entire perimeter to make balancing as easy as possible. To re-balance simply remove the set screws and start over with a clean slate.
We are currently testing this cover in Seven Devils- Idaho, Bend-Oregon and this weekend in Alpine - WY. We will have them up for sale on 02/25/2013.
http://www.snowestonline.com/forum/showthread.php?t=339455
Direct Replacement Rear Bumpers - Polaris PRO
We have in stock and ready to ship direct replacement bumpers for the 2011 to date Polaris Pro's. We have two lengths available. 10.5" that requires NO drilling and the 20.5" version. Both are much stronger than the stock version but cost right at the same cost as the factory unit. Ours are 1/8" wall powder coated Aluminum with threaded inserts to add strength. The tube is machined into the side rails to add substantial strength. Tow, Pull and Lift with confidence. All edges are smooth and all fasteners are flush on the exterior of your sled. We have provided the highest quality replacement bumper possible. These bumpers come with all new stainless steel nuts and bolts required for the installation. Check out our web site for more information and how to purchase. Dealer pricing available. WEB SITE WILL BE UPDATED ON WEDNESDAY 2/13/2013 TO REFLECT PRICING.
http://www.snowestonline.com/forum/showthread.php?p=3300589&posted=1#post3300589
