A
Arctic Thunder
Man that sounds bad.
Here's the deal.
I was working on a splice into my 12v wires for my fuel pump. I want to charge my fuel system with a 9v or 12v battery before I pull on the rope when it's real cold. So I cut the two wires, splice into it with another set of wires, I put a 12v battery from my four wheeler on it and the pump ran, sounded like it was under a pretty good load, then I had that wonderful smell of burnt wires and a small puff of smoke from my AC-DC gbpc25005 rectifier. So Crap! I cut the wires back off and make a direct connection. So now I have a butt connector that I unplug to prime the pump. This works really good. That way I don't have to worry about back feeding the capacitor or frying the rectifier. So I get it primed, and hooked up. Start the sled and my power is bouncing around, headlight is acting weird, fuel pressure was up and down, not holding, then again smoke from the rectifier. At this point EVERYTHING is just like it was for the last 1000 miles. So all I did was unmount the rectifier from the sled, started it to feel the temp and it worked like it should, no heat, power was solid. So whats the deal? (maybe a short from the aluminum back of the rectifier to the sled chassis?)
I will ask Stanger tomorrow but thought I would pick a few brains here. And in the process get it solved, that way down the road if someone else has a problem they can maybe find the answer here.
As of right now I will buy me a new one for under $3 bucks, and I think I will put a rubber backing behind the new one on the chassis to keep them from touching.
Thanks
Thunder
Here's the deal.
Thanks
Thunder
