I just remapped a customers Nytro with the new 310 hp set up and added a turbosmart boost tee. He wants to be able to easily adjust between 270 hp and pump to 310 and race. The sled was set bang on at 15 psi before installing the tee and as soon as I tested with the tee it went right to 21 psi. I have lengthened the wastegate rod 5 turns now without a reduction in boost. The contoller tee is turned all the way down + 3 clicks as ive heard bottoming the vale out will close the passage completly and cause high boost. I also cranked up the controller 5 or 6 clicks to verify it was functioning and instantly got 25 psi so I know it's functioning. Is it normal for a boost tee to have this drastic of effect on boost?
LL
LL
