Turbo Rx1 with new BIG GT28
Well need the money to rebuild my twin Mercs on my boat. Selling my baby, it is a 2003 RX1 Turbo (new about 10 gal of gas on it)GT28 turbo, coolant run to turbo, the sled has been unreal trail sled ,lake POWER FUN!! Now for some parts list,Brand New dalton adj clutch weights, windage plates,sway bar links,hood scoop, belly pan vent,short wind shild,hand gards, turn downs, Roxy wide running bourds, roxy riser, Apex seat with trunk, HUGE auto light boost gage, park knock box, Zr C.C. skid,(track does not ratchet with the Cat skid)straight front spring rate, updated coils, ARP head studs, Hallmond boost controller, Brand new track 10 miles on it, shock covers,geared up,reverse, blow off valve, Surprum Tool carb caps, o-ring billet aluminum Tees for carbs, Track on sled brand new 1" 6 pitch with BRAND new Woody chisels.
Wide band O2 with pcm play back, and i am sure lots of outher little things. This sled has been turn KEY!!! Sled is clean.
Have OVER $15,000 in this sled need quick sale!! $5999.00 Come steal this sled!! It is worth WAY more just needs to go NOW!! Sled turn key not hurt AT ALL!! If you are for real i have lots of brand new pics.
Thank you Matt 815-289-2555
The sled has a brand new alcohol water injection kit on it!! Just ROCKS big boost on
The sled has a brand new alcohol water injection kit on it!! Just ROCKS big boost on pump gas!! Powder pro skis......
Boost info: Turbo good to 28psi. Motor on race fuel and alcohol water injection 18 psi boost 310+hp!!! On pump gas and alcohol water injection 13-15psi 250-280 hp. These numbers should be real close!
Here is a small video of it with the small turbo!
http://www.youtube.com/watch?v=icIXQx8UxcE
Thank you Matt
