im planning to turbo my sled this year, although im going somewhat cheap on my turbo, BUT it will get me up and running,
to my knowledge there is a kit out, from attitude industries, for like $7000 with 1 or 2 aerochargers??? cant remember,
alot of guys end up making up their own home kit for it, ive heard guys say that the 1000 is not very finicky when it comes to turbo'ing,
but what i do know, is if one makes a kit for it, your going to want a 3071 turbo atleast, preferably a 3082, because the 3082 is a "hybrid" turbo and has a bigger compressor so it will build boost sooner i am told, you weld up your stock exhaust pipe at the crimped seams,
you get a Dobeck performance box, senses boost and adjusts fuel accordingly (probably have to call them and ask about it) your going to need new domes and get the domes milled out, because apparently the stock ones are bad for creating pre-detonation,
ontop of all that you also should have a egt gauge to adjust your fueling or let you know when somethings going wrong, Also needing as thick of a base gasket as you can get to reduce compression,
i think i have covered most of it, atleast from what i do know, im told stock injectors and stuff that way are good for up to about 12 pounds boost
