Now that my sled has been through break in and had a flash from the dealer, I seem to be hitting the rev limiter when riding aggressively in the trees. This usually happens when on/off the throttle repeatedly. I'm able to see ~8200 regularly with 8300 the odd time. Every once in a while I'll get a huge backfire and the sled will have no boost until I shut it down and restart it twice. Muskoka Freerider had the same issue in one of his videos.
I was on clicker 3 and went to 1 (also snapped the tip off the stock POS tool during the process) but the sled has RPM fade on long pulls now (7600-7700) but still sees ~8100-8200 when I initially mash the flipper. I was riding 6500-9500ft.
Can this be solved by changing to a heavier pin and dropping the clicker back to 3? The sled was a lot snappier there.... I'd prefer not to replace the entire clutch setup if I don't have to as I may not keep the sled depending what comes out in a few weeks.
I've never had the need to mess with one of these P drive clutches so go easy on me![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
