turbo question
well i had to take it on the lawn . i am very new to turbos . it is a apex bd 25 kit witch i installed my self . when iget on the gas for maybe 200 feet it falls flat on face allmost like blow off went off . is the blow off set or do you have to set it . how do you no where the waste gate is set if you trun it to the plus side means more boast . and to minus means less . please respond thanks
Sounds like not enough fuel or you are hitting the rev limiter.
Check what these guys said and also if you have a second fuel pump, some got out of production with the wiring thats sent in the kit back wards. So give that a quick check if you have a second pump. Mine was one that came that way and acted like yours is. :beer;
you guys could be right not enough fuel in tank . light is on . so is the blow off set . and how do you no where to set the waste gate all the way down till i ride it and turn up a little at a time . just 1 fuel pump in tank msd . thanks guys
