turbo question
I am really considering and want to put a boondocker turbo on my kx450f, I am just really struggling with the cost of the race fuel "vp c12 " is 130 for 5 gallons here .so basically for a full day of riding you are going to spend 120 ish on fuel. Am i correct or does running the higher octane result in less fuel ccnsumption. Was just looking to see how much fuel everyone is using the average price . I was also wondering if it was possible to run at a lower boost with pump gas or a spljt of pump and race fuel, Any imput is really appreciated thanx
You can run aviation fuel on a turbo bike. It is a lot less expensive than race fuel and still has what you need...100 octane, no moisture, some lead, anti knock. It will get the job done. I alternate between av-gas and race fuel and can't tell the difference in performance.
Stop at the Swift Current airport on your way west. Haven't been there in a few years but you used to be able to swipe your credit card at the pump and load up as much you have room for and can afford.
Avgas isnt very good imo. Was never developed for high rpm etc. If you dont want/unable to run good fuel i wouldnt turbo charge. Many have used 100LL in different applications without issues. However the majority of failures i have seen or heard about are with Avgas.
I would look at KMS performance also for a turbo and run some of these questions by him....
I use the 100LL (blue) avgas on my NOS 520 bigbore setup. Buddies on turbo bikes run the same fuel without issue. Not sure what RPM, prop / turboprop airplanes are running (probably less than a bike) but the application does require anti-knock and suitability to higher altitudes (uniform vapor pressure). 100LL meets the criteria. That said, it isn't specially formulated for bikes so there is a compromise.
Most small airports will carry 100LL since it is produced in sufficient quantities for non-military purposes. I buy mine a small airstrip in Sparwood, BC.
I've run 100ll in turbo Apexes for years. Talk about high rpm? Never had a problem. Of course, that 1L is a well built motor
Just mix race fuel and premium 50/50 . I do this with 110 sunoco in my turbo YZ. When i turn the boost up, I worry about other engine parts before I even think about detonation.
I agree to sticking with quality race fuel. If you are going to run a little motor that hard you want to have the best in it. I also run Klots fuel lube additive for four cycle engines in my Boondocker turbo KTM 450. I ran this bike hard all last winter and took it down to do a new top end in it this year and everything looked perfect valves were even still in speck.
Allen from Timbersled
