Turbo Pro Stock Suspension Setup Qs
J
JJ_0909
ACCOUNT CLOSED
Was hoping I could get some help from the collective setting up my sled's suspension now that I'm turbod.
About me...
Boost: 5-7lbs (depending on elevation/gas I can buy)
Elevation: 7-10K
Kit: Silber Reflash external wastegate (super smooth power delivery)
Suspension: Stock WEs - rear track shock revalved for stiffer compression tune.
Skid/track: 163 stock 5.1 track
Rider weight: 190lbs
Riding Type: Trees
Believe it or not the front end stays down more than I'd like it.
Running a fair amount of preload on my front shocks, rear shock's preload set about where the manual tells me, FTS ~ 6 threads showing from the bottom.
Thanks!
Stock shocks, the best set up is from TRS. BAR NONE!! It's just a slight turn on the RTS. Send em to Tony and let him work his magic. He runs a turbo too, so he will know just what you are looking for.
For now I would set to polaris specs and just tune the rts. Unless your season is done.
