Turbo pipe
H
HCM
What is the best pipe for a turbo m1000 I keep blowing holes in mine been welded hear and there have not seen much on them. I have a twisted Kit can get my hands on another stock pipe but if 9 lbs blows holes in them every ride I would like something better.
OVS sells a very thick gauge nicely tuned turbo pipe. No more pipe blowouts after installing one of those even at 18+psi.
D&D hands down. I run up to 30psi with mine and it has not cracked yet. I also did testing in Yellowstone with a stalker radar. Compared it to an slp and stock pipe and it was noticeably better through out the whole run. I thought the slp had the best throttle response but the radar proved me wrong.
Now I just need to figure out what to do welded the stocker back up again now to save up some coin to buy on of the 2 or just put another stock pipe back on this one lasted 2900 miles on boost.
I personally didn't have as good a luck with my DD on my first turbo project at 14 psi.......could have been learning curve.
I've seen four of the OVS piped sleds that work really well and no cracking. Can't speak of high boost radar run performance, but they are definitely made with thicker material, run really well, and cleaned up a lot of bottom end response issues.
That's a lot of miles on a stocker....hard to go wrong with another one, even if it only gave you 1/2 the mileage.
Good luck!
  • Like
Reactions: HCM
