Turbo Phazer Clutching?
Call Chris at Schmidt Brothers Motorsport. They are located in US but he has done alot of tunning with the phazer. mine has a supper running 10# and so i used his set up. He send a bunch of fastners that are pretty easy to tune. Here is what he set me up with. i can remember where i ended up at but i am pretty sure it was about as heavy as i could get it to keep it off the rev limiter on the hard pack. He was very good to work with.
the 8GC will probibly work. The 553G6 spring is accually white yellow white. I would suggest my stage 2 kit for the regular PZ because you already have the std PZ weights and that will save you $150, so if you order the stage 2 for the std phazer I will give you a custom set up that will work with those weights and you already have the red sec spring. Stage 2 comes w/ pri spring, weight combo for the 8GC weights and the custom multi angled billet helix for $259.99, I will throw in a bunch of tuning fastener that will work good for your app so you can tune it in.
Thank You
Chris @ SBM
Owner/President
989-756-2150
www.schmidtbrosmotorsports.com
