SylvanLaker
Building a Nytro motor right now pretty much as hard core as you can. I realize the 2860R that is in there will be restrictive and the right move is to go to a 2871R. There are a number of options available as you may be aware. I for sure need to run a .64 turbine A/R with a 76 trim as if I go to the .86 turbine A/R it will lag huge.
I have two options for the trim on the .60 compressor housing, I can get a 56 or a 48 trim. The higher the trim the more the turbo can flow but the more lag it will have.
So the question is what have you guys tried / ran on a rear mount with a well built Nytro engine??? My thoughts are to run the 48 trim as the 56 will lag to much, as the 2871 already flows more than the 2860, so this will be more efficient with the flow the engine can pump.
Any thoughts??
Any thoughts??
