i have a 99zr 500 i want to run the turbo feed line off of the bottom crank supply line. will the pump be strong enough to handle the supply line with out starving the crank bearings?
that bottom supply line doesn't feed much oil to the crank(waterpump shaft)
, maybe 4 oz per ride
I would suggest using the two injector lines for the turbo(ball bearing only) and premixing the motor.
