C
Let's see if we can re-invigorate the Twisted section.
Regarding oil to turbo. One problem I had last year was a failure in one of the check valves coming off the pump. The valve stopped being a one way check valve and was allowing oil to drain back into the pump, effectively purging the oil line to the turbo. It took almost 10 minutes for the line to fill back up with oil and begin re-supplying oil to the turbo. I don't know if this is an issue or not, as these types of turbos really need very little oil to be happy; however, I thought I'd pass on the info.
I am talking about the Arctic Cat check valves on the stock oil pump. Not something supplied by Twisted Turbos
I was checking my oil flow about every other ride and the oil was always right there everytime when the check valves were working properly. Maybe a light on a low pressure actuator switch isn't a bad idea; however, oil pressure is so low I doubt any current sending units would work properly. Perhaps some type of an oil flow meter would work.
Again, I don't know if it's a big deal or not, I just like the idea of oil making its was to the turbo bearing when it's spinning. Just food/oil for thought.
