I hope to have a more comparative analysis in a couple weeks. Boondocker just finished the turbo and a couple other companies will have theirs soon. I put some MC Xpress stuff on in the past and did not like the kits, so will probably stray away from that.
The SC has unreal bottom end. In fact it has too much and it needs to be controlled with a blowoff valve. This releases the boost at low RPM so you can keep the skis on the ground to steer. It has awesome bottom end in the trees, more than a modified M1000. On the top end it feels similar to a modded M1000 with a little extra. Not as much RIP as a turbo, but I have to have control, response, and durability where I ride. I also like the fact that if the SC takes a dump, I can just plug the stock wiring harness back in and ride home (like if a belt breaks, or a pully fails). The only bad thing is, that I know a stock Nytro will probably not climb out of the places the supercharger will get me in, but we'll see I guess.
It is a different ride (the Nytro) and I am still learing how to ride it, as I switch back and for the an M chassis on a daily basis.
I'll keep you posted.
50mm Tial BOV has been a proven winner. Try installing one of those. Let us know how it goes. Still skeptical on this end.RX FUN, what you just said is exactly what I am describing. If you chop the throttle the vacuum opens the valve to let the boost go. It makes the bottom end less jerky and uncontrollable. I might be describing it poorly, but without the blowoff valve the throttle chop and stab is a problem. I am not just guessing. I am riding.
Avid drivers...pretty much the only way to go
It will take a dumb the second you take it out of the box, there fuggin junk !!
That company could'nt get there issues with the Apex figured after 2+ yrs, and now there selling more junk that isn't reliable and works when it wants too. Seems to be a few companies like this these days
come on Darko, tell us how you really feel....
