I just got my mcx kit on my nytro and took it for a spin, I am getting 16,s on my a/f gauge as soon as the boost comes on in the mid. I haven,t been able to hold it wot yet snow is to hard, what are the rest of you seeing for a/f readings, thanks.
Those innovatives work like POO, not trying to bash the one you've purchased, but we've had nothing but issue's with those gauges, half the time the require a re-flash because the calibration's all out to lunch.
Took my sled (Nytro/MCX) out for the maiden voyage and was seeing high AF numbers on my Innovate xd16/lc1 gauge. I was also having a low power problem. (primary would not engage) I was told that I might have a pinched vacuum line on the fuel pressure regulator or off of the throttle bodies/brainbox or a kinked fuel line...causing it to run lean and not build any HP.
Could this be a similiar problem with yours?
After taking all the plastic off the sled and looking it over on the MTN, we found the bottom vacuum line on the fuel pressure regulator was touching the frame rail behind the headlight. I'm wondering if this might be the culprit. Pushed it away from the frame it ran awesome for about 10 minutes and then did the same thing again. I'm wondering if the line moved back over against the rail (didn't have time to check or pull it apart yet). Going to zip-tie it next time to try and isolate the problem.
