Y
yamaha3
I have seen other threads on here and on other sites that people are wondering if this is possible. Based on other threads and things that I have heard it is possible. I have heard that Dan Richter had a turbo mtn max in thunderstruck 3 and one of the earlier mountain mod mania videos, i personally have not seen any of them. Everyone on these other threads have said that they are going to do it and have already started, yet they cannot seem to post a picture.
Earlier this summer I decided that I was going to try it, so I started finding the pieces I was going to need. I mounted the turbo right off of the manifold where the three ports go into one. From there
Turbo - off of a 2002 Subaru WRX. (TD04 13G)
Intercooler - top mount off of a WRX
Exhaust - pipe done by myself ran into an SLP can
Intercooling piping - I pieced everything together (turbo to intercooler and also the piping I ran for the fresh air.
As far as jetting what I have read from other people that have turboed carbureted 2 strokes they use power jets. I havent quite figured out what I am going to do. More than likely I am going to use the power jets. I am also looking at different options that I have for fuel pumps.
The turbo is liquid cooled so I am going to tie that in with the coolant lines. I am thinking that I will take the carb warmers out since I have never used them and I will use those lines to do the cooling.
Now the trickiest part of the whole thing besides tuning will be oiling the turbo. I will have to have a catch can and a pump to get the oil to the turbo and it will be gravity flow back to the can. I have talked to some buddies that know turbos and they said an option that I might have is since that a subaru turbo is ball bearing I might be able to cap the drain off and fill the turbo with a good synthetic oil and then cap the top off and not even run a pump. They said I could probably get away with this
because it is liquid cooled. I was thinking about doing this for test puposes because if it doesnt work I would rather not have a pump laying around that is about $250.
I tore it all down tonight to paint everything. Tomorrow night after work I am going to re assemble and post pictures for you guys. I am hoping to be able to run it in a couple weeks as I am still waiting for a few things to get here.
Let me know what you guys think. Like I said this is all basically an experiment. I know that it is possible to turbo a carbureted 2 stroke soI thought that I would try it since no one else has posted any pictures or info on how they did it. I personally think it would be an accomplishment for myself and the people that have helped me.
Any suggestions or advice would help.
Thanks
Thanks
