So here’s what I’ve got going, I’m trying to determine if my lag is a product of the turbo I’m running or if it is caused by my clutching.
Turbo: I’m running a 2012 ‘153 800 with a Push Tial setup and vipec, this comes with a Tial external gate 2871 w/HTA billet compressor I’m not sure on the A/R of the turbine housing.
Elevation: 10,500’
Clutching:
82g cat weights with 122-285 titanium spring
36/46p helix with the plastic washers on both sides of an orange cat spring(don’t remember the spring rate)
I don’t believe I am having any binding in either the primary or secondary, clutch temperatures are hot but not IMO excessive, running the 084 belt.
Symptoms:
During normal riding when in and out of the throttle dodging trees and whatnot the sled is very responsive, tachs right up to 8250-8300 and goes like hell. Boost comes up very quickly and hits 9.5 and stays there, virtually no lag.
When moving very slowly, kind of crawling around and you hammer the throttle, again boost comes up quickly, very little lag.
When cruising at steady speed 30-45mph about half throttle and you hammer down it takes close to 2 seconds for rpm to come up to 8250-8300 and boost responds much slower than situations described above. At this speed and throttle position I am indicating around 3psi boost before opening up the throttle.
I have considered going to a higher finish rate primary spring but this would in turn require heavier weights to control rpm which would exacerbate the midrange laziness I think.
Any thoughts or suggestions?
Elevation: 10,500’
Clutching:
Symptoms:
