Turbo heads. Does it work with bullydog?
Davajn
Got a -14 silber kit(2863b) with bullydog on my pro and it feels like its abit to much runnning pumpgas on its lowest setting(8psi spring). Does it work with a leta say 12:1 turbohead, or is it to big of a change for the bullydog map?
Maybe......but we recommend leaving them stock. Any changes that you make could require fueling changes which you cannot do. We hope to have a simple fuel controller to work in conjunction with the Bullydog released soon.
Corey set mine last year I had stock compression turbo head that had way different fuel settings on my dobec controller than a stock head. So I would say with the bully dog you dont want to run anything other than the way the map is written.
Yeah its what i've figured out. Kinda new it before i posted it but just wanted to be 100% sure. Maybe justin has a map for low comp heads laying around?
Boston Racing that would be awesome if there would be a way to tune the bullydog as a enduser. Would give a whole new dimension to the kit!
The KPA wastegate actuator spring is set for 8psi min. It would need a different spring to run lower boost.
