H
hollycow
New member
Does anyone offer a turbo kit for carbed bikes? Someone on here said KMS was building a turbo kit for their 570 ktm which sounds like a carbed RFS motor.
Seen a lot of blow through systems on cars, but with a single barrel carb seems like you would not be able to add enough fuel. Maybe you could use a dial-a-jet or intellajet kit with two nozzels. I guess you could also add an injector with a tps signal, a/f sensor, fuel pump and control box but then you might as well remove the carb. Was interested in a RFS application. Thumper Racing has built a turbo RFS with modified CRF injection. The 07 Sherco RFS comes with injection you could probably pilfer parts off that. Just woundering if anybody has turboed a modern carbed big bore with any success. I know in the long run it is probably just cheaper to start with an injected bike.
