turbo fallin flat!
hi guy's, got a 06 m7 turbo. gettin pretty close to dialed in. the major issue i am having is that on a pull when i come out of the throttle and come back in my sled will fall flat on it's face. this happens at about 6,300 rpm or so. also on the trail pretty much the same, boost is at 3lb on trail when this happens, do you think it is my fuel pump, i see twisted has a upgraded fuel pump, thanks for the help.
I think your secondary is not backshifting Quick enough,,, If you stay in it after letting off does it eventually pull out of it????
Have the same thing with a M1000 2010 BD pump gas
Running about 7 to 8 lbs boost with 110 race gas
Have the updated EBC
45lbs fuel pressure
elevation? how much boost? race gas? if your running under 9 pounds above 8500 feet race gas is more than likely the problem. race gas burns slow and cold and tends to make everything rich at high elevations. try trimming back to 50/50 or even less. my m8 does the exact same thing at 9 pounds on race gas. most of the year iv been at 10-11 pounds on straight 91 and its running perfect. oh yes..... near 4000 miles under boost 95% of the time on 91 maverick gas:face-icon-small-ton
