Can anyone help me find a twisted turbo dealer and good installer in Alberta or b.c all I can find is bd and am not one hundred percent sold on the kit. I have a 11 m8 153 will be runnin 10 psi or so on av gas at around 4000-8000 ft with stock head
CPC is my suggestion. An the boys a white knuckle in lloydminster can hook you up an know their stuff!! We got two kits from them last year an did own installs an will always help a guy out. Both kits ran awesome all year 10-12 lbs on 100LL
did you guys keep the stock head on or did you change heads to 09 lower comp?
Buddy only has 2 injectors he on stock head still running 10. I was hitting my det sensor wen it was stock for 150 miles. Then in Revy trying to ride 4-5k I couldn't get more than 8 lbs outta it with stock head an wanted more. (Reeds were also going an blew good the last day so could be why) but i wanted linderman turbo cut anyways so i changed. But he never hit det once so I mite have an over sensitive sensor seeing how I hit it stock a few times.
ok thanks for the info.
