Turbo boost psi
wwillf01
I have an analog boost gauge... how close are they to reading true psi... I ended up coverting my push 250 to an oft ecu without the extra injector and running race fuel... I am running barely 8psi and it feels so much more powerful than the push with the 250 upgrade... IA M told above 10000 feet I can go to 10 psi...
If your afr numbers are ok and your running good fuel I wouldn't be scared to run 10lbs. The power commander really makes a big difference in the way it runs wouldn't you agree!
Holy crap did it ever... I run 2 psi lower and it feels like there is 30 more hp;)
I have 3 rides on it and I like it.. well worth the money if you have the dobek ecu.. oft customer care has been second to none
Why do you need to run race fuel at 8 psi? The push kit is designed to run 8psi right out of the box. I got my push kit with the PCV from the start and it does work well.
I am being careful at this point.... I am thinking my gauge is off... at 8 it feels like there is so much more power... once I get enough snow to have a load on the track I am hoping to get some better readings... but my afrs start inching up to a reading every once in a while of 14 when I go to 10psi but I think it is the crap snow... or I am loosing my sensor again which would be disappointing... when I get a few seconds of snow load where I can find it I seem to be able to be in the 12'S and and 13 here and there... it feels so good though so hopefully with the snow we are getting over the weekend I will be able to test again early this week..
A common misconception is that if I make an "x" amount of boost it will make that much power when this isnt true, good tuning to utilize the boost is what makes power, and there are so many variables from fuel tuning to how efficient the turbocharger system is. for example lets compare a boondocker sidemount turbo apex (the most inefficent set up IMO) to a midmount turbo apex with equal length headers, external wastegate, stand alone ECM TUNED PROPERLY! water to air intercooler.
I can garuntee heads up @ 15psi it would be a landslide win for high end tur bo kit. inefficient set up = heat=less power. good flowing exhaust and dense cold charge air equal big power. But all of that is useless if the compressed air can't be mixed perfectly and at the right time. Look at how many people have a turbo kit with a cheap dobeck style fuel controller are now using either Vipecs or boost it fuel systems and they work amazing, I went from dobeck to boost it and it was night and day difference and the turbo set up itself never changed. Cheap fuel injection systems do not account for enough variables to consistently run well in our constant chaning environment and running conditions.
you boost gauge is good, your sled was just never tuned optimally till now
