R
redbull660
I have a 2008 nytro with a turbo, can someone tell me how the blow off valve works and what its purpose is. It came with a couple different springs to try.
You figure out what spring to use based on the amount of vacume you pull at idle.
Ok....... so am I looking for more or less vacuum? My boost gauge has a vacuum reading on one side and a boost reading on the other side. If I had to guess I will be looking for more vacuum at idle. I am new to this so any extra tips would be great. thanks
RedBull whos's kit do you have??? They should know what spring is going to work the best.
Cutting the spring will reduce preload but actually increase the spring rate so it would be best to install a softer spring of the correct length if it actually needs it. If you can detect the BOV opening any time you let off of the throttle then it is functioning. If it only blows off when you slam the throttle shut from wide open throttle then you probably need a softer spring.
By the way... Zeb has no idea what he is talking about!
Brad
