Spur
My Apex stops idling and is throwing a code 14. I cleaned all electrical connections and thought I had problem solved. After about an hour of riding it started doing it again. It will not keep idling while stopped, and is impossible to keep running while coming down hills even if I try to assist with the throttle. It seems to get worse at higher elevations. Once you get it started if you can keep it running long enough to engage clutch it drives out ok and won’t die until you let off the throttle. The problem is a little inconsistent. I have left it with a reputable Yamaha repair shop twice. Both times they have not been able to help. Its several hours back to the dealer. Anyone have any ideas I can try from home?
Thanks
Thanks
