Turbo, any suggestions!!
I have a new pro r 800 with about 200 miles on it now, and have been thinking about installing a turbo kit. I am at low elevations and can only run about 4psi of boost. any suggestions about reliability!
if you are only going to run 4psi you might as well save a few grand and get a single slp pipe or something, its just a big undertaking and alot of money imo
im sure you would have fun either way
silber turbo
There is no reason why u cant run a turbo at 4 psi it is still worth it in case u do ever want to go out west a turbo out there is a must and even at home if u want to get crazy get some aviation gas and turn it up to 7 or 8 I live in Minnesota and still run a turbo its worth it every ride and really worth it when I go out west. If u are going to get a turbo I would strongly recommend silber turbo I have road one of the sleds they have and they are insane very responsive and are very smooth. The kit is also a hundred percent bolt on witch is un heard of in the turbo market and it has a special billet machined throttle body boot that is o ring fitted and houses the secondary injectors. Also from what I have read and personally meeting Justin he has the best customer service around check out the web site silberturbo.com
Low elevation and boost
Low comp domes/head and 10psi on premium, that's fun :) Silber Turbo would be able to helping you with getting a good setup.
