When you use a CR or VE tunnel do you run the stock cooler under the tunnel or just the running board coolers, stock front cooler, and rear cooler of the tunnel? Are those enough to remove the radiator or would you still have to get the coolers from mpi and run them as well. And will they fit on a CR or VE tunnel?
