G
gjp
I snapped the Running Board Gusset which bent the skid drop mount and sheared off some rivets. I removed the gusset plates last season, but re-installed with Aluminum rivets after purchasing MadFab's board inserts. The damage was more extensive because of the soft rivets used. I can see now how those plates reinforce the setup.
The rivets from the parts diagram are 3/16 HUCK rivets. Hopefully dealer has a huck rivet gun.
I did some research on rivet strength:
3/16" Alum: 445/720 lbs (shear/tensile)
3/16" Steel: 590/815 lbs (shear/tensile)
3/16" Huck: 1700/1050 lbs (shear/tensile)
A/C does not sell the skid drop plate so I had to straighten it. I don't have pictures yet of how I straightened it but I used about 3 tie down straps and sucked the tunnel together and used steady pressure to bend everything back. Much easier than I thought. The sheared rivets took most of the force and saved my tunnel.
So if you removed your gusset rolls I would suggest re-installing them with Huck rivets.
