Tunnel bag for a 17 SBA
A
Alancour
I'm looking for a tunnel bag for my new SBA and would like some feedback/recommendations.
Im mostly concerned with keeping things dry and possibly holding a few beverages. I see that the power keg has an optional can holder.
I do not want to drill my tunnel.
I am considering the following bags.
Burandt adventure LG bag
Polaris premium lock & ride Backcountry
Powder Keg P-700-B
NXTLVL QR Freeride
Sled Solutions E-Series elevation
The large Polars/Burandt bag would not fit on the Pro-Ride SBA because it was too long, but the small fit. I'm not sure there is more room to work with on the Axys SBA, but it is something to check.
bag
I put a sled solutions bag on my axys I took an hi fax cut it the width of tunnel drilled holes in hi fax used 1/4 bolts wich fit into the slots on polaris mounted bag directly to the hi fax used plastic wing nut on the hi fax bolts so i can remove bag easily . This also raises Bag off tunnel for more air flow. when there s low snow or Ice help the cooling in theory . Maybe this will help you ! Will try to post pictures This way you can use any bag you want
Another bag you should check out is Mountain Addiction. Thay have a few options available and a nice mounting system.
