Tunnel Bag and Tunnel Contact
Picked up a RMK in the spring (coming from a Summit) and looking at using a Lock and Ride Clam style (Burandt) tunnel bag this season. My question is does anyone offer/make a bracket or rack that lifts the bag up so it does not sit directly/make contact on the top of the tunnel? I thought I found something before that fit into the rails on the tunnel that lifted Accessories up, but cannot find it.
Thanks.
Doesn't that bag have a plastic tub base so that you can mount it directly to the tunnel? Anyway, I offset my underseat bag last season with a thick sheet of plastic, but you could do it with aluminum too. It worked awesome at keeping everything dry.
The Burandt Tunnel bag sits directly on top the tunnel w/4 lock and ride clips into the grooves. I have used the Burandt bags (Worn one out and bought another) for maybe 3 or 4 yrs. Love 'em. Easy to configure and organize, sits tight to the tunnel (no flopping around), low profile. Interchangeable between my Axys RMK (155x2.6) in the Mtns and a SBA ((144 x 1 3/8) on MN trails.
I have not seen a spacer of any kind. Not sure if that would work unless the spacer is a mostly solid plate. The base of the bag is fairly stiff, but not enough to hold the bottom of the bag flat without support under the entire surface. Then if a solid plate, i think I've defeated the intent/purpose.
Overall, haven't noticed any issue with cooling the sled that can be contributed to the presence - compared to lack there of - the Burandt tunnel bags, even on the trails going up to, and down from the good play areas - compared to the scratchers being up/down (which make a huge difference) - far more than having the bag tight to the tunnel could cause.
Great line of thinking, but I feel a non-issue in this case - IMO
Thanks for the replys, was thinking of mounting the bag off the tunnel to protect the tunnel wrap from wear and on my Summit whenever i used a tunnel bag it always ran warmer, sounds like this isn't a issue with the RMK.
Sent from my SM-G950U using Tapatalk
I like to keep my bags off the tunnel, seems to help with sweating and keep inside stuff dryer. Not sure how u would space with the lock a ride. Unless u made the entire plate removable.
Just made this last week for my bca bag, and add a little extra storage under it, bunje that doesn't get used, and some extra waters
