Completely 1000% false and over analyzing, at idle or even 2k rpm the bike makes 2HP tops. When riding i red line clutch drop the bike all day long at 50HP shock loading the belts. including landing drops and over stumps...It's your alignment or tension. Warming up the bike to reduce clutch sticking shock loading had 0 to do with it. Think about the belt shock load when you hit a stump burried under the snow. I am no trying to be mean or say anything but just help you out, good on you for warming the bike up that's critical for not seizing a piston but in terms of belt. It's a fly in the universe. Also just to clarify you may be torching a belt due to a cold stiff belt not due to the clutch sticking. The belt needs to warm up to gain strength, polymers strength reduction at cold temperatures is massive. Belts fail due to hammering on the gas with a cold belt not clutch plates.There is another situation where one can inadvertently stress a belt; On a cold start, your clutch plates are often stuck together and don't free up until they are warmed up and/or broke free. It takes a lot of force to break them free when stone cold. Meaning, you pull the bike out of the trailer, start it, and within a minute, go to click it into gear so you can pull it around to a different spot along side the truck. You pull in the clutch, shift it into gear and clunk; the bike dies because pulling in the clutch didn't release the stuck clutch plates so shifting it into first acts like you didn't even have the clutch lever pulled in. That abrupt driveline shock is very hard on the entire driveline, but especially belts. Some make/model bike clutches stick more than others and oil used is a contributing factor. I had an issue on a previous snowbike build and realized I needed to really let that bike warm up (10 - 15minutes) before that first shift so the clutch plates would release. My latest build is less prone to it, but still, I no longer move the bike to a more convenient spot nor do that first shift into gear until after it warms up 10 minutes or so (depends on ambient temperature that day).
I was thinking the same thing?? full power landing jumps on a 155 3in track and 180 hp? I feel like thst shock exceeds what a bike can put downAfter beating quick drive belts to death on my boost?
Assuming they use the same belt construction…….
I don’t think a Snowbike has any worries…….
